AutoCAD Forum
this message always come out when I working on the CAD file
6 REPLIES 6
kinman_cheung
301 Views, 6 Replies
what is happening or something wrong with system?
6 REPLIES 6
jayhar
in reply to: kinman_cheung
What Message, Please upload screenshot. any error in CAD file Open New File RECOVERALL > Browse CAD file & AUDIT
upload your cad file
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
kinman_cheung
in reply to: jayhar
Dear Sir,
The message attached please help?
##- This application has detected a mixed version of AEC objects
participating in this operation. Newer AEC objects will be disallowed from
participating in this operation. -##
KM Cheung
cadffm
In your drawing are informations of older and/or newer Versions of AEC-Stuff = special Object data from vertical versions which are not plain AutoCAD or LT)
(or you only save the file to an older File-Version)
What product are you running? (Screenshot of dialog ABOUT)
Sebastian
john.vellek
Hi @kinman_cheung,
As @cadffm explained, there are objects in your drawing and possibly in your templates that came from a vertical product or toolset and possibly came from different versions.
I suggest that you install any applicable object enablers and then consider an performing an exporttoautocad.
You are welcome to attach one or more of your drawing files to a post so I can take a closer look.
John Vellek
jayhar
 An appropriate object enabler is not installed to support the AEC objects.
Do one of the following:
1, Use the -EXPORTTOAUTOCAD command (or AECTOACAD) to resave the file.
2, Install the needed object enabler.
3, Open the file in the newer version of AutoCAD which last saved it.
4, Use AutoCAD Architecture to open Architectural Desktop files, or revert to Architectural Desktop itself.
5, In AutoCAD Land Desktop, use the Format/Explode setting in the Civil Batch Drawing Converter utility to resave the file.
kinman_cheung
in reply to: jayhar
I believe it helps on my problem, but I need to wait for our IT admin. to install the latest AutoCAD version on my pc.
Forma Design Contest
AutoCAD Beta
