what is happening or something wrong with system?
Solved by john.vellek. Go to Solution.
Solved by cadffm. Go to Solution.
What Message, Please upload screenshot. any error in CAD file Open New File RECOVERALL > Browse CAD file & AUDIT
upload your cad file
In your drawing are informations of older and/or newer Versions of AEC-Stuff = special Object data from vertical versions which are not plain AutoCAD or LT)
(or you only save the file to an older File-Version)
What product are you running? (Screenshot of dialog ABOUT)
Sebastian
Hi @kinman_cheung,
As @cadffm explained, there are objects in your drawing and possibly in your templates that came from a vertical product or toolset and possibly came from different versions.
I suggest that you install any applicable object enablers and then consider an performing an exporttoautocad.
You are welcome to attach one or more of your drawing files to a post so I can take a closer look.
I believe it helps on my problem, but I need to wait for our IT admin. to install the latest AutoCAD version on my pc.
