Text is diffrent size from one computer to another
Message 1 of 10
text in enhanced attribute editor is appears in a different size from one computer to another. Both computers are in the same drawing scale. Both computers have same text styles loaded, both heights are the same yet on one computer they are a much different size even though they both say they are set to the same size and style.
Can someone Help?
Replies (9)
Message 2 of 10
imadHabash
turn OFF your hardware acceleration from GRAPHICSCONFIG command .
Imad Habash
Message 3 of 10
I turned it off, restarted computer and opened up another drawing and same thing is still happening. any other ideas of what to do?
Message 4 of 10
user181
Is the text annotative? If it is you may have the incorrect annotative scale set on the drawing that is appearing incorrectly.
Message 5 of 10
imadHabash
try ANNOALLVISIBLE = 0 , any changes ?
Imad Habash
Message 6 of 10
both drawings are at the same annotative scale as well
Message 7 of 10
Patchy
Probably because of the fonts, go to each dwg and check the style see if they both annotative.
Read this post:
https://forums.autodesk.com/t5/autocad-forum/text-displays-differently-in-different-files/td-p/43051...
Message 8 of 10
I set it to zero, changed the scale of the drawing to match that of the annotative scale, the font corrected it self but after I saved closed and reopened it was just as it was before I changed it, still not sure how to fix this problem permanently
Message 9 of 10
pendean
Community Legend
Community Legend
>>>...both drawings are at the same annotative scale as well..<<<
Not according to your screenshots: do yourself a huge favor, post a video of you opening this file "on the other computer", let us see the whole process, including but limited to you changing annotative scales, also identifying the STYLE being used then opening STYLE command for us to see what the settings are.
Use this freebie recorder https://knowledge.autodesk.com/search-result/caas/simplecontent/content/download-autodesk-screencast...
Message 10 of 10
I cant download the screen recorder (work network wont allow me) I attached another screen shot of the enhanced attribute editor.  still not sure what I can do to fix this problem so when I  open the drawings up on the other computer they stay in the correct scale with out having to change the annorset everytime
