Text field showing layer description
joseZ9KZ7
joseZ9KZ7
Hello all,
I'm using Autocad 2020 and I would like to insert a Text field that shows the layer description.
I know that I can show the layer name but I want to show the layer description.
Any ideas?
Thank you very much.
Ed__Jobe
I don't think a field is going to be able to do that, but you could place text in the dwg. Here is a lisp that inserts text for all the layers. You could modify it to suit your needs.
Ed
How to post your code.
vladimir_michl
You can display Layer Description in a Text Field but how do you select the layer? Do you want the current layer? Or a selected object's layer? Or a fixed layer?
If you want to display a possibly changing description of a fixed layer, you can just replace the property in the layer (named objects) field code - e.g.:
%<\AcObjProp Object(%<\_ObjId 2097988848992>%).Description>%
Vladimir Michl, www.cadstudio.cz - www.cadforum.cz
joseZ9KZ7
It would be the layer description of a selected object.
did you get any success with it? I think i'm trying to do the same thing, i Want to display the layer description but in the Field options i can only find the layer name option. Is it possible in any way?
vladimir_michl
The layer description is "too far" - you will need to get the name of the layer from the selected object, get the Object ID of that layer and then get its Description property. I doubt this can be done just with fields. But it is quite simple in LISP, and maybe you can also add some kind of reactivity to it.
gros33
@Anonymous
You can copy the NamedObject field expression (without the %), paste it and change 'Name' to whatever property you'd like 🙂
For example:
<\AcObjProp Object(%<\_ObjId 3111172414224>%).Color>
or
<\AcObjProp Object(%<\_ObjId 3111172414224>%).Description>
just add % at the start and end
you're welcomed
