Plot - Fit to Paper Issues
Message 1 of 10
Hi, Thanks in advance for your help!
I have "fit to paper" selected but my plots and PDFs are not fitting the entire paper. My drawing is fitting about 1/4th of the paper.
Replies (9)
Message 2 of 10
jayhar
Hi @Anonymous
1. Scale your Title block in Paper size (A1 or A3)
2. Create New Page Set Up Using DWG To PDF .pc3.
3. Select A1 Or A3 Size.
4. Plot Area Select By Window
5. Mark Center To Plot
6. Fit To Paper
7. ok
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
JAYHAR.M.J
Asst: Team Leader
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | AutoCAD randomly crashes or freezes
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Message 3 of 10
RobDraw
It works fine here but you didn't include the referenced images.
If you want to print to scale, do not use "fit to paper".
Rob
Message 4 of 10
imadHabash
you have to check the other settings NOT only " Fit to paper " , from PLOT dialog check :
  • What to plot ( Window ) .
  • Center the plot .
  • Drawing orientation ( Portrait , Landscape ) .
Imad Habash
Message 5 of 10
BrianBenton
If you're plotting to FIT, then scale doesn't matter (I hope and assume) so I suggest using a selection WINDOW. Just window around the area you want to print. Keep in mind that while everything that is drawn to scale will be to scale, relatively speaking, but not printed to a specific, pre-set scale.
Brian C. Benton
bbenton@cad-a-blog.com
http://CAD-a-Blog.com
twitter.com/bcbenton
www.facebook.com/CADaBlog
Message 6 of 10
RobDraw
If you look at the file, the layout is sized for 11x17 and the printed paper size is tabloid. It should be printed 1:1. No need for the fit option.
Rob
Message 7 of 10
BrianBenton
I agree. I guess I wasn't clear with what I meant. If somebody is printing to "fit" you negate the scale of the drawing and the drawing size/scale doesn't matter. It's going to "fit" on the paper but it won't be to a real scale.
Yes this file is set to tabloid, etc, and should be scaled at a 1:1. Printing from paper space should typically be done at a 1:1 scale.
Brian C. Benton
Message 8 of 10
vladimirvay
Just experienced the same problem with someone elses drawing. Set to Fit to Paper - PLot extents, the preview looks good, but when created PDF file (Print to PDF), the last line was cut-off. I tried many variations, the only work around was changing Plot to Windows (in What to Plot).
Never experienced the same problem with my own drawings.
Message 9 of 10
cadffm
It's an problem what can appear with files/pagesetups from older versions.
Sebastian
Message 10 of 10
pendean
Community Legend
Community Legend
Show us: post that DWG file here for someone to dig deeper to identify the trigger/problem.
