Switch off Display Plot Styles
I've searched and searched and I can't find a way to simply set the Display Plot Styles variable to off. (unchecked) I don't want to toggle it off/on but instead just set it to 0. Is there a system variable I can set in the command line? I have hundreds and hundreds of files that I need to do this to and I have written a script to automate several other things and I'd like to add this as well. Thanks,
Replies (11)
Alfred.NESWADBA
No, that is not a system variable, it's a setting of each single layout/pagesetup.
So you need to go through each layout and either uncheck "display plot styles" (or assign "acad.ctb" as plot style?)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
-FDC-
Right click on the layout tab.
Select "page setup manager".
Click modify.
Unselect "display plot styles"
cwr-pae
And this needs to be set in templates to default off in all future drawings.
So there is no way to automate this process to uncheck the box on multiple drawings?
-FDC-
I'm afraid you cant't.
But you can do multiple layouts with the Publish command
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Select...
-FDC-
Or you can try it with the command dwgconvert.
Never tried it though (see attached YouTube video).
https://www.youtube.com/watch?v=rjuHqhN2LAs
pendean
Community Legend
Community Legend
Post in the LISP forum for help with coding it to run as a startup every time you open a file https://forums.autodesk.com/t5/autocad-customization/ct-p/AutoCADTopic1
jayN4FCL
Community Visitor
Community Visitor
I wish this were an option. it is really annoying going into page setup every time.  Autodesk ~> Please make us a solution 🙂
nanja_c86
Try this one the toggle plot style display for layouts only.
(defun c:togptl (/ doc layouts count index layout currentLayout showPlotStyles);Toggle plotstyle display for layouts only
(vl-load-com)
(setq doc (vla-get-activedocument (vlax-get-acad-object))
layouts (vla-get-layouts doc)
count (vla-get-count layouts)
index 0
currentLayout (getvar "ctab") ; store the current layout name
;; Check the ShowPlotStyles state of the first layout (excluding model space) to decide the toggle action
(setq showPlotStyles (vla-get-ShowPlotStyles (vla-item layouts 1))) ; assume the first layout is not model space
(while (< index count)
(setq layout (vla-item layouts index))
;; Skip model space
(if (/= (vla-get-name layout) "Model")
(progn
;; Switch to the layout
(setvar "ctab" (vla-get-name layout))
;; Toggle the ShowPlotStyles and lwdisplay
(if (= showPlotStyles :vlax-true)
(progn
(vla-put-ShowPlotStyles layout :vlax-false)
(setvar "lwdisplay" 0)
(progn
(vla-put-ShowPlotStyles layout :vlax-true)
;; Enter model space, regen, and return to paper space
(command "_.MSPACE")
(command "_.REGEN")
(command "_.PSPACE")
(setq index (1+ index))
;; Switch back to the original layout
(setvar "ctab" currentLayout)
(vla-regen doc acAllViewports)
(princ)
RSomppi
If something like this is needed on a regular basis, named page set-ups could help speed this up.
