Message 1 of 10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm seeking assistance with a severely corrupted DWG file I received. The issue is incredibly perplexing:
- All elements in the file are strangely referenced from a missing XREF. It's like everything is within a single, absent block.
- Although I can see the contents, any attempt to interact with the XREF is futile – detaching, reloading, exporting, etc., are all inexplicably disabled. This essentially renders the file useless.
Frustrated, I attempted to open it in SketchUp and explode it there for export back to DWG. This worked, but tragically, the process stripped away crucial information: all blocks, linetypes, colors, layers, and other element properties are missing.
Therefore, my desperate plea: how can I truly explode this file and retain all its original properties? Any knowledge or alternative solutions would be a very appreaciated!
For further analysis, I've attached the problematic DWG file.
