Announcements
Block Library Palette Can Only Addd Ten File Folders?!
2557003216
2557003216
When add the eleventh folder, autocad is stuck forever!This is a huge bug?!
Replies (7)
Valentin_CAD
@2557003216 ,
Try this suggestion:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
cadffm
>>"Block Library Palette Can Only Addd Ten File Folders?!"
Only one folder (or DWG) is the active library
and only the last 10 are listed in the drop down for recent libraries (incl. the current one).
>>"When add the eleventh folder, autocad is stuck forever!"
That shouldn't do that.
>>"This is a huge bug?!"
It is a bug if everyone with the same software can reproduce it.
What productversion are you using? Please share a screenshot of dialog, command: ABOUT
Try another windows user or your account with admin right, same problem?
Also, please share a screenshot of this entlarged list and block palette
Sebastian
cadffm
@2557003216  schrieb:
>"2024"
Works well for me on Win10, it is a problem on your side. Test it with another win user, do not migrate old settings.
Thats the only idea i have.
>"there is no remove folder button?"
For what? It's working by first-in first-out princip and there is no need for it.
BUT, I am with you, I would like this option too.
I prefere right-click on file in list -> remove.
>"After I delete some folders, it works fine"
..until the list is 10 long again and then, it freeze again?
Never read about this issue before.
@cadffm - moderated to remove the NDA information.
Sebastian
Yes, after deleting some folders, it works fine even adding ten more folders.
cadffm
ahhh, that solved the whole problem.
Thanks for clarification.
May I ask, what was your way to delete some of them?
Sebastian
It's a hassle, you need to delete the original folder, then select the files you want to delete, and Autocad will notify you to confirm whether to delete or not.
pendean
Community Legend
Community Legend
Thanks for sharing your tip.
