AutoCAD Forum
Sticky Cursor
17 REPLIES 17
Message 1 of 18
noli1057
8521 Views, 17 Replies
Sticky Cursor
Ever time I select dimension/Text or any entities to modify, it become sticky or freezing in a while. It affecting my work time frame very much. What causing this? How can I turn this out.? Thanks for any helpful response you guys here may have...
17 REPLIES 17
Message 2 of 18
noli1057
in reply to: noli1057
Any responses to this issue from the expert here?
Message 3 of 18
nrz13
In AutoCAD 2015 or 2016, type GRAPHICSCONFIG and turn off hardware acceleration to see if that helps.  Or, if it's off, turn it on.
You can also try unchecking all the boxes under the Preview section on the Selection tab in Options.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 4 of 18
noli1057
in reply to: nrz13
Thanks for your response. I already tried that both on AutoCAD 2014 & 2015. They both have the same condition. Recently, we upgraded my Graphic Card from K2000 to K4200 NVidia Quadro with two 32 in Monitors and then this happened. My system are Window 7 Pro, HP WS 620 Xeon (R) @ 2.1 GhZ, 8 GB Ram,. We thought this gonna be even more faster but this freezing issue had taking my production slow. I also changed my window screen to the basic as some guy suggested, still nothing had changed. Any further help from you guys please? Thanks..
Message 5 of 18
nrz13
Do you have the Autodesk Certified Driver installed for your new graphics card?  What is the resolution of the 2 monitors and what type of cable are you using to connect them to your computer?
Message 6 of 18
noli1057
in reply to: nrz13
Thanks nrz13, I just reload my CD for driver, I will let you know if that will work. For Monitors, I have Samsung 32" 2560X1440 resolution, 88.8 kHz 60 Hz, and its connected in HDMI port. Also, see attachment for Tuner Log.
Message 7 of 18
nrz13
I would use the driver I linked to, which is certified for AutoCAD, instead of the one on the CD.  I was thinking you might have two 4K or 5K monitors, which could put a lot of strain on the graphics system, but what you have seems reasonable to me.
Message 8 of 18
in reply to: nrz13
Do you have the properties window/palette open?
If so close it...
Message 9 of 18
ahmed.abdelmotey
try to check your atuocad fonts directory and delete fonts that you don't use .. maybe it will help.
Ahmed Abd-Elmotey
Landscape Architect & beginner lisp programmer
Message 10 of 18
It may help to check the following things:
- Do you have considerable amounts of Images, Wipeouts, OLE Objects in your drawings ?
- Do you have layers switched off (but not frozen) where large amounts of objects reside ?
- Are there Point Clouds (LIDAR) Data, even far off screen ?
- Are you working with a 3d _shademode instead of 2d ?
- Are there many snapmodes (_osnap) switched on (2D and/or 3d), or tracking modes or the snap (F9) or the grid (F7) ?
- Do you have LWDISPLAY always on ?
- Do you have Blocks with very detailed graphics, maybe very small, or with wipeouts inside ?
- Did you try to experiment with options->display->Display resolution and Display performance ?
- Did you try to alter options->drafting->Auto Track settings (i.e. switch them off)
- Do you have many scales in your drawings (I had recently one with hundreds, it was awfully slow) ?
- Do you have usually very big coordinate values ?
- Does this behaviour occur if you start from scratch with no objects, adding elements gradually ? Or does it depend on certain projects/drawings ?
- Did you try to isolate your workstation from every network (temporary disabling any network card)
- Is there any other application running on your machine, which could interfere, or use much RAM that Acad then lacks ?
regards, k.
Message 11 of 18
noli1057
in reply to: nrz13
nrz13, I guess you are correct. After I downloaded your provided link of certified driver, everything become smooth. No more sticky or freezing cursor, I can now easily open text and dimesion for editing even the Layer and Properties Manager window are open. The only problem I have seen during downloading is... it did not recognize the monitors that flashed out in the screen. Still, it's ok That's really helpful. I wonder why the CD provided by the Nvidia with the new graphic card package did not really work well since its their own product. Anyway, thanks a lot nrz13, you're very direct to the point, very detail and no silly things to ask. You deserve to be an great Advisor in this CAD Community. Thanks a lot and God Bless.
Message 12 of 18
nrz13
Glad I could help. The reason the CD driver is not necessarily the best is that it is used for any number of games and programs, whereas the one on the Autodesk site (also by NVIDIA, by the way) has been specifically tested in AutoCAD. Newer drivers are not necessarily better, as changes in the newer version could have conflicts with AutoCAD.
Message 13 of 18
noli1057
in reply to: nrz13
I thougth everything would be smooth after I got help from a good guy here in this forum. A week after, the problem came up again. Still taking slow especially when editing text and dimension, even in a new drawing. Any more help about this issue please?
Message 14 of 18
Is your property window open?
Sent from my iPhone
Message 15 of 18
noli1057
I tried that! Please read the whole posted responses including my replied post. We have tried all those. Still, no luck 'til this time.
Message 16 of 18
noli1057
I just attached the Tuner Log of my WS for your reference.
Message 17 of 18
I encountered last week a problem like yours and after seeing that nothing could solve it, recommended to update the machine from 8 to 32G RAM dualchannel - 16G it got then, old RAM was removed. That did the job, on a 64Bit Win 7 machine.
Message 18 of 18
Another idea is the small amount of virtual memory in the log's os section. If that's in bytes, if it's in kbytes, then not. A more crude idea I had was, if acad is accidentially configured to start in xp compatibility mode on that WS.
Forma Design Contest
AutoCAD Beta
