I am running a standards check using a company standards file I have assembled, and it is only working for some of the plugins. I can check drawings for Layers violations and Linetype violations, but not for Dimensions violations or Text Style violations. The command seems to run, but no window pops up. This is a relatively fresh install of AutoCAD. Any idea why Check Standards would only work for half the plugins?
Rob
Did your tic all box there under Plug-in?
Make sure it same like this(Please refer attached image)
Or
In your standards file Dimensions & Text Style are not there.
Yes, I have tried checking all the boxes, each individually, and each combination. The ones that do not work are Text Styles and Dimension Styles. The other plugins seem to work fine.
