AutoCAD Forum
Standards Check Not Working for Dimension Styles and Text Styles
2 REPLIES 2
rmarcalowCNV7Q
409 Views, 2 Replies
I am running a standards check using a company standards file I have assembled, and it is only working for some of the plugins. I can check drawings for Layers violations and Linetype violations, but not for Dimensions violations or Text Style violations. The command seems to run, but no window pops up. This is a relatively fresh install of AutoCAD. Any idea why Check Standards would only work for half the plugins?
Rob
Tags (1)
2 REPLIES 2
Did your tic all box there under Plug-in?
Make sure it same like this(Please refer attached image)
Or
In your standards file Dimensions & Text Style are not there.
Yes, I have tried checking all the boxes, each individually, and each combination. The ones that do not work are Text Styles and Dimension Styles. The other plugins seem to work fine.
Forma Design Contest
