AutoCAD Forum
AutoCAD Lt, 2020. Finish plating compensation question.
1 REPLY 1
320 Views, 1 Reply
In AutoCAD Lt, 2020 is there a way to draw the part to final size then automatically compensate sizes for .0004/.0006 thick plating?  I want to make a print for our machine operators to machine a part so when the plating is applied, the part is in size.  The thickness of the plating is .0004/.0006 thick and some of of the dimensions are tolerances at ±.00075 so I want to give them a "actually hold this dimension" print.
1 REPLY 1
pendean
There is no 'compensate" drawing option: you draw to your hold-to dimension and add notes for the rest is the common practice.
AutoCAD Inside the Factory
