In AutoCAD Lt, 2020 is there a way to draw the part to final size then automatically compensate sizes for .0004/.0006 thick plating? I want to make a print for our machine operators to machine a part so when the plating is applied, the part is in size. The thickness of the plating is .0004/.0006 thick and some of of the dimensions are tolerances at ±.00075 so I want to give them a "actually hold this dimension" print.
