AutoCAD Forum
Space Between Dimensions
2 REPLIES 2
wdranada
379 Views, 2 Replies
Hi everyone,
I usually do my dimensioning (annotative) in model space. Now, I want my dimensions to be 10mm apart from each other (in paper space). Is there any way that I can do that without guessing on model space and then checking it again on paper space? Thanks, everyone.
2 REPLIES 2
pendean
in reply to: wdranada
That's not something you can control with annotative dimensioning, since by its nature it is designed to change sizes all the time.
Most likely you will need to go old school and use non-annotative, and create a unique DIMSTYLE of each print-scale you need to use.
wdranada
in reply to: pendean
I guess I'll have to do it manually.
Forma Design Contest
