Renaming layers
Renaming layers
yollinge
Renaming layers
yollinge
Hello Community,
I get troubles in renaming a lot of layers.
I am using AutoCAD 2019 and want to rename 100 layers in one step in a drawing i recieved. I used the command rename layers (REN). I have selected the layers i want to rename. After using the wildcards who exists they never changed those layers
I want to change *TEXT* in  *Text*. Exist there another possibility to change this in the 100 layers.
I thank you very much for your precious help
Yves
ВeekeeCZ
I would search for some kind of custom routine that allows real wildcard find/replace.
I attached one I have, unfortunately, dunno from who.
Just fill the last two fields TEXT and text.
HERE  is a quick tutorial of how to use a LISP in case is needed.
