AutoCAD Forum
Solved: Explode 1 line in Autocad
6 REPLIES 6
843 Views, 6 Replies
Hi all,
Now, I'm want to explode 1 line in autocad 2015. I try to using explode command but i can't. It is a line export form Cam350.  Thank.
6 REPLIES 6
Attach file is file i want to explode.
Alfred.NESWADBA
You have 3 block-insertions and one polyline in the DXF, I can't see a line.
When you start command _EXPLODE and select your entity, what does AutoCAD tell you in the command-line?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
cadffm
@Anonymous
The explode command worked!
You had a blockreference, after explode you get the content of block as separate object(s),
in this case you get a polyline (with width >0).
When you explode this object, you a circle (in this case).
before->now->afternextExplode
Blockreference->Polyline->Arc
I am guessing you don't want a simple ARC object?
Please check my attached file, perhaps you trying to get this result.
Sebastian
in reply to: cadffm
Hi Cadff
It's my mean. How to do it. Please share it.
Thank you.
cadffm
In this case it isn't possible directly with plain Autocad.
When you explode a polyline(with width-propertie >0) the width go away.
Why? No other objecttype has this propertie. In this case a circle..
A simple way to do: Use a 3.part tool like that http://www.lee-mac.com/advpolyoutline.html
Sebastian
in reply to: cadffm
Hi Cad,
Thank you so much
AutoCAD Inside the Factory
