Solved: Explode 1 line in Autocad
Hi all,
Now, I'm want to explode 1 line in autocad 2015. I try to using explode command but i can't. It is a line export form Cam350.  Thank.
Attach file is file i want to explode.
Alfred.NESWADBA
You have 3 block-insertions and one polyline in the DXF, I can't see a line.
When you start command _EXPLODE and select your entity, what does AutoCAD tell you in the command-line?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
cadffm
@Anonymous
The explode command worked!
You had a blockreference, after explode you get the content of block as separate object(s),
in this case you get a polyline (with width >0).
When you explode this object, you a circle (in this case).
before->now->afternextExplode
Blockreference->Polyline->Arc
I am guessing you don't want a simple ARC object?
Please check my attached file, perhaps you trying to get this result.
Sebastian
Hi Cadff
It's my mean. How to do it. Please share it.
Thank you.
cadffm
In this case it isn't possible directly with plain Autocad.
When you explode a polyline(with width-propertie >0) the width go away.
Why? No other objecttype has this propertie. In this case a circle..
A simple way to do: Use a 3.part tool like that http://www.lee-mac.com/advpolyoutline.html
Sebastian
Hi Cad,
Thank you so much
