Am using Autocad 2016.
A book I am reading says to use Solid subtract to delete blocks from the walls at the door locations.
I tried this but nothing gets deleted. Why is this?
Thank you for your help.
Hi @Anonymous,
You are using surfaces instead of soild walls, so you must subtract box/block from both sides of wall or create your 3D walls use Polysolid command in the solid tab of ribbon.
@Anonymous wrote:
I succesfully drew Polysolids.
But when I delete the boxes, no holes remain. It just disappears.
Attach file here that exhibits this behavior.
