Short mouse lag (3–5s) when opening AutoCAD files – CPU/GPU/RAM all normal
emile_madi
Observer Observer
emile_madi
Observer
Observer
I’m having a weird lag issue in AutoCAD and I can’t figure out the cause
What happens:
When I open AutoCAD or open a drawing, my mouse lags/stutters for about 3–5 seconds
After those few seconds, everything becomes perfectly smooth
The lag does not happen continuously, only right after opening files or sometimes when AutoCAD initializes
System:
CPU: Intel i7 / i5 12th–13th gen (tested both, same behavior)
GPU: NVIDIA RTX 4050 (laptop)
iGPU: Intel UHD / Iris
RAM: 16 GB
Storage: NVMe SSD
OS: Windows 11
Laptop (Gigabyte)
What I checked:
CPU usage during lag: below 30%
RAM usage: normal
Disk usage: normal
Temps: normal
Power mode: High performance
Happens even on small/simple drawings
After the initial lag, AutoCAD runs completely fine
GPU confusion:
In Task Manager, AutoCAD sometimes shows:
No GPU engine
Or “GPU 1 – Copy” instead of NVIDIA
I tried forcing AutoCAD to use the NVIDIA GPU (Windows graphics settings + NVIDIA Control Panel)
Issue still happens
Other notes:
UI lag is worse when AutoCAD panels are fully expanded
If I minimize panels (tabs/buttons), mouse lag is reduced or gone
This makes me think it’s UI / graphics initialization related, not raw performance
CGBenner
@emile_madi
Hello, there is a little more information that could be helpful.  Please share with us the version (including updates) of AutoCAD and what type / model of mouse you are using.  Are all drivers up to date?
Chris Benner
pendean
Community Legend
Community Legend
@emile_madi Where are you storing your files? How are you accessing them from your laptop
Is this a VPN connection?
USB drive?
Something else?
OS is? Year version of AutoCAD is? Have you installed the latest AutoCAD Update yet? ABOUT command in your AutoCAD will confirm what you have installed, compare that to your Accounts Updates list or grab a screenshot and paste it over here for guidance.
Since you are reporting GPU issues... Set GFXDX12 variable to 0 (that's a zero): a restart of your AutoCAD is required for it to take effect.
manieshkumar.suresh
Hi
Duplicate of this post - Short mouse lag (3–5s) when opening AutoCAD files – CPU/GPU/RAM all normal - Autodesk Community
Maniesh Kumar Suresh
Escalation Lead
If this information was helpful, please use the Accept as Solution function — it helps other users.
