Short mouse lag (3–5s) when opening AutoCAD files – CPU/GPU/RAM all normal
emile_madi
Observer Observer
emile_madi
Observer
Observer
I’m having a weird lag issue in AutoCAD and I can’t figure out the cause.
What happens:
When I open AutoCAD or open a drawing, my mouse lags/stutters for about 3–5 seconds
After those few seconds, everything becomes perfectly smooth
The lag does not happen continuously, only right after opening files or sometimes when AutoCAD initializes
System:
CPU: Intel i7 / i5 12th–13th gen (tested both, same behavior)
GPU: NVIDIA RTX 4050 (laptop)
iGPU: Intel UHD / Iris
RAM: 16 GB
Storage: NVMe SSD
OS: Windows 11
Laptop (Gigabyte)
What I checked:
CPU usage during lag: below 30%
RAM usage: normal
Disk usage: normal
Temps: normal
Power mode: High performance
Happens even on small/simple drawings
After the initial lag, AutoCAD runs completely fine
GPU confusion:
In Task Manager, AutoCAD sometimes shows:
No GPU engine
Or “GPU 1 – Copy” instead of NVIDIA
I tried forcing AutoCAD to use the NVIDIA GPU (Windows graphics settings + NVIDIA Control Panel)
Issue still happens
Other notes:
UI lag is worse when AutoCAD panels are fully expanded
If I minimize panels (tabs/buttons), mouse lag is reduced or gone
This makes me think it’s UI / graphics initialization related, not raw performance
manieshkumar.suresh
Downgrade to DirectX 11 from DirectX 12 (See How to use a previous DirectX version in AutoCAD Products)
using this system variable GFXDX12 as 0 and restart the AutoCAD for  the smoother performance with DirectX 11.
You can try this system variable
System variables
  • Set CACHEMAXFILES to 0, restart the product and set it up to 256 again.
  • Set UCSDETECT to to turn off the UCS detection.
  • Set SELECTIONPREVIEW to 0.
  • Set STATUSBARAUTOWRAP to 0
  • Set DYNMODE to 0.
  • Set QTEXTMODE to 1, then use REGEN to regenerate the view.
  • Set BLOCKMRUMODE to 0.
Maniesh Kumar Suresh
Escalation Lead
If this information was helpful, please use the Accept as Solution function — it helps other users.
BhaskarMurari
@emile_madi Ensure your NVIDIA RTX 4050 driver is updated to the latest version. If the issue persists, try rolling back to an older driver version, as newer drivers sometimes cause cursor lag.
Also check:
  1. Right-click the desktop and choose "NVIDIA Control Panel".
  2. Switch to the node "3D Settings - Manage 3D Settings" and turn off Global Settings property "Vertical Sync".
