data extraction on entity TEXT
-didier-
Advisor Advisor
-didier-
Hello
I'm here to share with you what I've just noticed:
When drawing TEXT entities we are given the possibility to choose a justification,
It is possible to choose to draw the text from the point MIDDLE CENTER, LOWER RIGHT etc...
BUT
when extracting the data (DATAEXTRACTION) and asking for the insertion point of the TEXT entity
AutoCAD ignores the justification and indicates the LOW LEFT point ignoring the chosen justification.
This picture describes what I just explained:
Three texts of color magenta, orange and blue each inserted at point 10.0,10.0 but with a different justification and below the table delivered by the data extraction where we can see different coordinates of position.
The same happens if we send the data in an Excel workbook instead of a table in the drawing.
and I find it inaccurate because the Excel data could be used to query contact information and then you lose information.
I know perfectly well that the insertion point is convoluted in the list of the TEXT entity in the case of a justification different from LOW LEFT but I would have liked the programmers of the software to think about this "detail".
And in your case, it is the same?
My test was performed on a full 2021 version.
more precisely R. 118.0.0 AutoCAD 2021.1
Friendly
this is a software translation because I'm not really bilingual like many French people...
but I speak perfectly autoCAD
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
cheryl.buck
Autodesk Support
Autodesk Support
Hi @-didier-,
Thank you for posting your observations and question. This is correct for data extraction since the AutoCAD text box is not being extracted, only the text contained in it. The XY position is based on only the text itself and will change with the justification of the text.
Please let me know if this helps.
Click the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
