How do I delete/transform proxy objects?
I have a project where I need to delete or transform proxy objects to be able to use  WBLOCK. I tried to download zonmbiekiller but this didn't work as it collided with the plugin Novapoint, that i use, and caused a fatal error.
Is there another plugin or command that lets you delete proxy graphics from a drawing?
The drawing contain proxies since they are generated from a GIS database so I wont e able to obtain a proxy-free version from the client.
pendean
Community Legend
Community Legend
AECTOACAD or EXPORTTOAUTOCAD commands, look up usage in HELP, or this install freebie https://apps.autodesk.com/ACD/en/Detail/Index?id=1498235021060360128&appLang=en&os=Win32_64
I tried Zombiekiller but it didn't work. I tried to say that in my first message but maybe the typo made it hard to read.
The commands you recommend both export the whole file but I only want a selection of a few layers to be exported, and cant find a way to do that with these commands, Exporting to DXF doesn't help with this either. Exporting to .dwf does do the trick in terms of only exporting the selected layers but I cant work with that format.
Any other ideas are much appreciated!
pendean
Community Legend
Community Legend
Ask the person that uses "novapoint" to remove them for you, you most likely will never be able to on your own in plain AutoCAD.
murray-clack
I tried to attach a file called "DelProxy.vlx", but it wouldn't let me attach the file.  Do a Google search and you will find it
pendean
Community Legend
Community Legend
@murray-clack ZIP the file then post if if needed.
