AutoCAD Forum
Shift Key and ortho lock
8 REPLIES 8
Message 1 of 9
786 Views, 8 Replies
I've tried to fix the problem with Shift key to temporarily override ortho, but nothing seem to work
I'm using AutoCad 17 on windows
Thank you
8 REPLIES 8
Message 2 of 9
Patchy
CUIX and fix it, or just reset your autocad to default.
Message 3 of 9
imadHabash
it's long story ... i doubt that it could be fixed . I've read many post's and discussions and still not fixed . i hope it could be .
Imad Habash
Message 4 of 9
pendean
Works fine here in R2017.1.2 if you are patient enough to wait for the 1-second delay, and if your primary CUIs file is set up to do it (see Patchy's reply for a fix if not).
Message 5 of 9
Alfred.NESWADBA
What have you tried?
Have you tried both settings for TEMPOVERRIDES?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 6 of 9
ChicagoLooper
To temporarily override ortho mode, hold down the control key, and continue holding it down, while you work with your mouse. To reinstate ortho, release the control key. Alternatively, toggle ortho using F8.
Chicagolooper
Message 7 of 9
in reply to: Alfred.NESWADBA
Yes, I have
I also tried fixing CUI shortcuts
nothing works
Message 8 of 9
in reply to: ChicagoLooper
doesn't work
Message 9 of 9
Use command "TEMPOVERRIDES" and set it to 1
Forma Design Contest
