Whenever I am using a Sheet Set, and I attempt to "Publish to PDF" after setting up my PDF Publish Options, I am experiencing unexpected behavior under the following conditions:
- Multi-Sheet File is being produced
- Prompt for name is unselected and is using a pre-populated name for the final file:
![sgeraciC5Z7G_0-1690401339543.png sgeraciC5Z7G_0-1690401339543.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1245525iE01EEDD062D764B0/image-size/medium?v=v2&px=400)
This will result in the PDF being sent to my default plot location instead of the named path. This only happens under these conditions. Prompting for a name, or unselecting Multi-Sheet then allows the PDF(s) to be plotted to the correct path.
