AutoCAD Forum
Sheet Set "Publish to PDF" Error
0 REPLIES 0
Message 1 of 1
sgeraciC5Z7G
145 Views, 0 Replies
Whenever I am using a Sheet Set, and I attempt to "Publish to PDF" after setting up my PDF Publish Options, I am experiencing unexpected behavior under the following conditions:
- Multi-Sheet File is being produced
- Prompt for name is unselected and is using a pre-populated name for the final file:
This will result in the PDF being sent to my default plot location instead of the named path. This only happens under these conditions. Prompting for a name, or unselecting Multi-Sheet then allows the PDF(s) to be plotted to the correct path.
Labels (4)
0 REPLIES 0
Forma Design Contest
AutoCAD Beta
