Interesting.... usually its either SSLOCATE or SSMAUTOOPEN that is not set to '1' - both should be for SSM to open automatically when an SSM-enabled drawing is opened/linked to an existing DST file.
This may be related to the version/creation date of the DST or the SSM files. I have read online that SSM files/templates originally created from older versions of AutoCAD 'can' occasionally create an functionality issue where something isn't working correctly. FYI - I have not experienced this directly myself.
However, I have had a couple DST files go bad (where something went wrong, perhaps corrupt, bloated, etc.). Generally we will rebuild the DST from scratch (slow, tedius) or completed the following:
- Open AutoCAD and Open the effected DST within SSM
- Go to Windows Explorer and locate the DST file
- Cut/Paste the effected DST file to a backup location (or DELETE the DST outright)
- You will notice the DST file magically returns (rebuilds automatically)
- Return to AutoCAD, close/shutdown to save changes/write back to the DST
- Restart AutoCAD and check SSM issues/functionality to see if they remain
Question: Does this SSM issue occur on all SSM projects opened in Civil 3D 2017? What about for other users (get another user within your office to open the SSM project/file and see if the same issue is replicated)?
- If it's replicated it could be more of a global issue, requiring SSM templates/files to be updated to current version.
- If the issues cannot be replicated, it could be a drawing issue/error, user profile or something related to an install problem/fix required, etc.
Keep me/us posted on what you identify in your testing. Good luck!!
Chad Franklin
