AutoCAD Forum
sheet set custom field
2 REPLIES 2
183 Views, 2 Replies
I set a custom property for a sheet set. However, when I insert a field into my drawing which is linked to the custom property I just set up, it appears "####" instead of the number I set.
I have tried redraw, regenerate my current workspace and restart the program, restart my computer. However, it still shows up like ####. I am sure the field was linked correctly.
Could anyone explain and help? Thanks
2 REPLIES 2
john.vellek
Hi @Anonymous,
Is the FIELD nested in a block? If you explode it does it then work properly?  Can you share your file and the Sheet Set? I also need to know which version of AutoCAD you are using.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or question. Please mark my post as the solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Forma Design Contest
AutoCAD Beta
