I'm running AutoCAD 2016 and have set the default out put device within my profile, however when I click print this device is not showing up as my default. Any ideas?
Solved by pendean. Go to Solution.
Solved by imadHabash. Go to Solution.
What you show us in the image affect only the new drawing . existing drawings are not affected by this settings.my advice is to use Page Setup Manager because AutoCAD uses a page setup to set an output device for each drawing instead of using a default device for any drawings.
File tab > Page Setup Manager
Good Luck..
Imad Habash
