Sequentially numbered blocks in AutoCAD
I am working with my office's template here at work.  We use a pre-made block to number our workstations in our drawings.
The problem with what we are currently doing is that we have to edit each attribute within the block to have each workstation get numbered, i.e. 001, 002, 003 and so on.  Is there a way where I can create a block that would start at 001 and then each time I insert/click it would sequentially number them? That would save us hours of time.
Thank you!
 @Anonymous
john.vellek has edited your subject line for clarity: Sequentially numbered blocks
Accepted solutions (4)
imadHabash
 There are many outsource ways that could achieve what you're asking for , i suggest to see this . >> Click <<
Imad Habash
john.vellek
Hi @Anonymous,
Here is an old but reliable routine by Jeffry Sanders that was posted on CADALYST in 11/05 (Tip2068).
The link in Imad's post didn't work for me but I believe it was to this routine from Lee Mac.
John Vellek
JTBWorld
Our app JTB Text Bubble Plus could be an option: https://jtbworld.com/jtb-text-bubble-plus
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
pendean
Community Legend
Community Legend
Freebie on the Autodesk App Store called Increment is worth exploring, so easy to use and understand
https://apps.autodesk.com/ACD/en/Detail/Index?id=8051485828049059617&appLang=en&os=Win32_64
john.vellek
Hi @Anonymous,
You have received a good number of suggestions here in this thread.
I am coming back to your thread to see if the issue or question you posed has been resolved.  If so, please mark the post or posts as Solution(s) to help others find the answer quickly. If your issue persists, please give me a bit more detail on this issue so we can continue to work towards getting this solved.
John Vellek
