Solved by nestly2. Go to Solution.
It works as described in HELP here. It is important to hit SHiFT before SPACE, otherwise the SPACE is recognized as <enter>
The other possibility is that SELECTIONPREVIEW is disabled. In order to cycle through the objects, you need a visual clue, so SHIFT+SPACE won't work if SELECTIONPREVIEW = 0 and SHIFT+SPACE only works when a command is active if SELECTIONPREVIEW=2
In the animation below,
SELECTIONPREVIEW = 3 (default)
LEGACYCTRLPICK = 2 (default)
With regard to the missing linebreaks in your message, your browser (or your IT department) is probably blocking one or more of the scripts (javascript) the forum uses for text formatting (ie lithium.com and addthis.com)
I am trying to Fillet two lines. The cycle symbol shows up on the first line I pick but not the second line. I can only pick the the object in the front.
YOUR AWESOME Nestly!!!
I changed the COMMANDPREVIEW variable to 0 and Selection Cycling works just fine now!
Thank you very much!
I just right clicked on the selection cycling button and selection cycling options appeared and i chose display selection cycling list box!
