SELECT SIMILAR not working as expected
toolbox2
Message 1 of 21
toolbox2
I've set SELECTSIMILAR to select objects based on layer name alone but it's not working. It selects objects based on layer and object type.
Same with selecting by colour only. It seems to select by colour and object type.
Any ideas why this is happening?
Using AutoCAD Map 2016 (64 bit); Win 7
Replies (20)
Message 2 of 21
imadHabash
just to remind you to check the settings.
Command: SELECTSIMILAR
Select objects or [SEttings]: se
Imad Habash
Message 3 of 21
toolbox2
Yes, I have set the options using Settings. And double-checked by looking at the SELECTSIMILARMODE sysvar.
Message 4 of 21
imadHabash
make sure that your objects have a BYLAYER color.if you want to post some of these objects here as CAD file sample to test it for you in our systems.
Imad Habash
Message 5 of 21
toolbox2
Here you go. New drawing based on a standard AutoDesk template.
Message 6 of 21
imadHabash
if do you want to select every item carried a certain layer,then you have to try QSELECT command.
Imad Habash
Message 7 of 21
RobDraw
What you are describing is the way it is designed to work. By selecting the object, you've already said that you want to select all similar objects. The additional settings are to modify that selection criteria. So, if you want to select all lines regardless of layer, you would tell it to ignore layers.
If you wnat to select all objects on a particular layer, there are ways to do it, but SELECTSIMILAR is not it.
Rob
Message 8 of 21
toolbox2
So, did SELECTSIMILAR not work for you either?
It's weird because I've used this command for years and not noticed a problem with it.
Message 9 of 21
RobDraw
It's not a problem. That is the way it is supposed to work.
Rob
Message 10 of 21
saifullahaddress
i checked but its not working in Auto CAD Civil3D.
Message 11 of 21
sarahsarah2015
same here, doesnt work in civil3d
Message 12 of 21
cadffm
If you have the same issue, read the message! It doesn't say it is not allowed in Civil,
but in files what saved in newer Civil versions (or with objects from such a file).
Sebastian
Message 13 of 21
sarahsarah2015
I dont understand what you are trying to say. but here is the help of autocad civil 3d which does not work.
Message 14 of 21
cadffm
You wrote to saifullahadress "same here" so I looked what saifullahadreas issue is (the image in the post above yours)
so you are talking the same issue ("same here,").
I don't understand your screenshot of adesk help documentation,
it can't explain your problem.
But as you can read in this message, what is the same on your side, because you have the same issue,
there is a reason why it won't work.
Q: Do you have the same problem (same message) or not?
If not, why don't explain your (different) issue?
Sebastian
Message 15 of 21
pendean
Community Legend
Community Legend
@sarahsarah2015 wrote:
same here, doesnt work in civil3d...
...I dont understand what you are trying to say. but here is the help of autocad civil 3d which does not work. ...
The error message in the post you are referencing is quite clear about why it's not working
You also posted a screenshot of a command that C3D may not actually be using, there are two in C3D, here is the difference
https://cadapult-software.com/select-similar-in-civil-3d/
So now you have to find out:
1) are you actually using the correct command, and is it worth trying the other?
2) what "newer version application" last touched your DWG file to make this option not work anymore.
You probably should have been posting in the dedicated C3D forum this whole time too, but you opted not to do so. You might not quite get the correct C3D solutions you need here.
HTH
Message 16 of 21
lylakal
I have same problem and does not go away with updating autocad. all select similar options are check, and select similar does not select similar.
Message 17 of 21
lylakal
I have same problem and does not go away with updating Autocad. Even all select similar options are check, and select similar does not select similar.
Message 18 of 21
cadffm
Post a sample  .dwg with only 2 objects (please delete all other stuff),
what should select by selectsimilar, but doesn't.
I am sure that we can point to this one  problem.
Sebastian
Message 19 of 21
vladimir_michl
Here is an extended version of SelectSimilar which allows the "by object type" option. Plus it works also in AutoCAD LT a AutoCAD Web. See
https://www.cadforum.cz/en/selectsimilar-extended-selections-for-autocad-incl-lt-and-web-tip13878
Vladimir Michl, www.arkance-systems.cz  -  www.cadforum.cz
Message 20 of 21
lylakal
thank you very much for quick response, I found my current issue.
