AutoCAD Forum
scale factor calculator
3 REPLIES 3
738 Views, 3 Replies
I always get trouble with using one function in AutoCAD. Whenever I want to use the little calculator to apply a scale factor to a Block in AutoCAD, AutoCAD stops working. I have to go to task manager to turn it off manually. I really do not know why it is. I tried re-start my computer, but it does not help. This is not about size of file since I asked my co-worker to test a same file, it works fine for hers AutoCad
3 REPLIES 3
dbroad
I would suggest a reinstall or repair install.  There's no reason this should lock up AutoCAD.  If the layer is locked though, it just won't work.
Architect, Registered NC, VA, SC, & GA.
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I suggest that a Reset Settings to Default and then also check for hotfixes and service packs from here.
Please post your status after these steps have been taken.
John Vellek
in reply to: john.vellek
Thanks very much. My problem is solved after i reset setting to default. But I still updated  hotfixes and service packs as you said.
Forma Design Contest
AutoCAD Beta
