I always get trouble with using one function in AutoCAD. Whenever I want to use the little calculator to apply a scale factor to a Block in AutoCAD, AutoCAD stops working. I have to go to task manager to turn it off manually. I really do not know why it is. I tried re-start my computer, but it does not help. This is not about size of file since I asked my co-worker to test a same file, it works fine for hers AutoCad
Solved by john.vellek. Go to Solution.
I would suggest a reinstall or repair install. There's no reason this should lock up AutoCAD. If the layer is locked though, it just won't work.
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I suggest that a Reset Settings to Default and then also check for hotfixes and service packs from here.
Please post your status after these steps have been taken.
Thanks very much. My problem is solved after i reset setting to default. But I still updated hotfixes and service packs as you said.
