AutoCAD Forum
Running AutoCAD from the Cloud
8 REPLIES 8
Message 1 of 9
mlynch
599 Views, 8 Replies
We have recently moved all our data to MS Azure blob storage, except for Revit models, which we have in BIM 360. We still have a fair amount of work being done in AutoCAD, and it had become a significant pain point for us. What is the AutoDesk recommended manner in which to run AutoCAD from cloud storage? IS BIM 360 the answer? One of our offices, who use sheet set manager and extensive customization, found BIM 360 no real improvement over simply running DWGs from the cloud drives, which is god awful. I've seen some articles on Web-based sheet managers (https://help.autodesk.com/view/ACDLT/2023/ENU/?guid=GUID-45700EEC-B549-4879-9C8C-7C23AB54B112)
Not sure exactly what we've done in this regard, but I thought I'd ask here to see if anyone has successfully figured out how to run AutoCAD, at speed, from the cloud.
Thanks!
Labels (2)
8 REPLIES 8
Message 2 of 9
vladimir_michl
in reply to: mlynch
This is a list of storage providers which can be used in AutoCAD Web app:
Vladimir Michl, www.arkance-systems.cz - www.cadforum.cz
Message 3 of 9
paullimapa
in reply to: mlynch
Autodesk Docs is the way to go. Talk to your reseller to get more info and on pricing
Paul Li
IT Specialist
@The Office
Message 4 of 9
mlynch
in reply to: paullimapa
Thanks!
Message 5 of 9
mlynch
in reply to: vladimir_michl
Thank-you!
Message 6 of 9
paullimapa
in reply to: mlynch
you are welcome...cheers!!!
Paul Li
IT Specialist
@The Office
Message 7 of 9
RobDraw
in reply to: mlynch
You marked the wrong post as the solution.
Rob
Message 8 of 9
mlynch
in reply to: RobDraw
Sorry! Thanks for letting me know. Too many details to attend to. Have a good holiday!
Message 9 of 9
RSomppi
in reply to: mlynch
You can uncheck your "solution" also.
Forma Design Contest
