AutoTurn - turn path shows up in Model Space only
mmXSRCR
Message 1 of 9
mmXSRCR
Hello, this is my first time posting to the CAD forums so I appreciate the advice.
I have double checked that the turn path is on the right layer, and checked whether that layer is frozen in the viewports (it's not). When I isolate that layer in model space, the turn path disappears. Any idea what might be causing this issue?
Thank you.
Replies (8)
Message 2 of 9
paullimapa
post sample dwg with that problem
Paul Li
IT Specialist
@The Office
Message 3 of 9
mmXSRCR
Hello Paul,
Thank you so much for your help! The layer is "AT Trash Truck Berth 4 IN - Alternate3." It won't show up in the "Trash Truck Berth 4 - alternate" page viewports, even though it shows up on the "Trash Truck Berth 5" page.
Message 4 of 9
M_Hensley
When I looked at it the layer for AT Trash Truck Berth 4 IN - Alternate is frozen in that viewport.
Message 5 of 9
mmXSRCR
I realized I have too many layers in there with similar names for that turn attempt. The "AT Trash Truck Berth 4 IN - Alternate" layer does show up for me when I unfreeze it in that viewport. However, I'm still having trouble with the "AT Trash Truck Berth 4 IN - Alternate3" layer.
Message 6 of 9
M_Hensley
When I freeze all layers except AT Trash Truck Berth 4 IN - Alternate3 there is nothing on that layer.
Message 7 of 9
mmXSRCR
I get that result too. It does seem to work in the example I posted when the "AT Trash Truck Berth 4 IN - Alternate3" layer is current and a new turn path is created on that layer. I tried the same thing in my original file, which has many xrefs and some layer names even longer than the ones in the example. In the original file, I still had the same issue. I will try cleaning up my original the way I did for my example - by using the PURGE command and shortening some layer names. I'll see if that helps and post the results here.
Message 8 of 9
cadffm
I edited this post, because i wrote about another part of your drawing,
but the main problem (how layer properties ON/OFF and FREEZE/THAW works) is still the same.
Nested objects, nested blocks and layer usage  - the structur is not well done in this drawing.
basic layer&block knowledge, all works as normal.
Your Blockreference of Block *U466 for example refers to Layer "AT Trash Truck Berth 4 IN - Alternate3"
but the turn path and all other objects inside your block referes to "AT Trash Truck Berth 5 OUT - Alternate"
But your block contains objects on another layer only!
All content is refering to Layer "AT Trash Truck Berth 5 OUT - Alternate"
and this layer is VPFREEZED in that viewport!
A quick inside to Layer and Blocks:
Layer ON/OFF show or hide object which refer to this layer.
Layer Thaw/Freeze load or remove objects which refer to this layer from editor.
AND:  For Blocks&Xrefs: Is a layer freezed and one blockreference refers to this layer,
the blockreference remove from the editor (wich means: also all the content disappears,
because there isn't longer the Blockreference object, which display the block content.)
You also have a viewport on layer "AT TRASH TRUCK BERTH 4 IN - ALTERNATE3",
have a look more on your layers.
Sebastian
Message 9 of 9
mmXSRCR
Got it. Thank you @paullimapa, @M_Hensley  and @cadffm for your help. Looks like I need to do some more reading on blocks and layers in AutoCAD, and keep in mind AutoTurn paths are always created as blocks. Have a great day!
