Rotate view using X, Y & Z on origin
Yashasvi23481
Yashasvi23481
Hi Support,
    I am trying to make this view as Front view. Currently showing as bottom. From prev thread, i learnt to copy this view and change the orientation to Front on top left and paste it. But i want to know, is there a way, i can rotate the view using X,Y & Z direction on origin?
  I dont want to use the navigation on right side as its meant to be showing Top all the time. Just want to ensure if there is a way, i can rotate using X, Y & Z axis to achieve this view as Front and not bottom. If so how and which direction to rotate?
Please see attached screenshot.
Thanks in Advance.
Yashi
Accepted solutions (4)
paullimapa
In my recent article I discussed how to use AutoCAD's -VPOINT command to get different orthogonal views:
AUGIWORLD by AUGI, Inc. - Issuu
For front view:
-VPOINT
0,-1
Paul Li
IT Specialist
@The Office
rlpgmlo
Try 3DROTATE command.
Tomislav.Golubovic
Use the UCS. Set the view you want to make the "Top" and then type in UCS, then V for View and it'll make it the top set to the current view direction.
leeminardi
To reorient the object in World space so that the World front view shows the desired orientation try the following:
rotate3d
All
x
0,0,0
-90
lee.minardi
