AutoCAD Forum
Rotate to vertical horizontal
5 REPLIES 5
7144 Views, 5 Replies
Instead of inputting an exact angle, or having to align to a horizontal/vertical line, could we please have the option to making a line within the selected geometry, horizontal/vertical. I'm certain this feature exists within other autodesk products.Untitled.jpg
5 REPLIES 5
ВeekeeCZ
Sure.
UCS Object <select a line>
PLAN Current.
Or set UCSFollow to 1, then you don't need the second line.
in reply to: ВeekeeCZ
Hi, thanks for the suggestion, but I only want to rotate certain selected
geometry, not the entire drawing. Is this possible?
Cheers
Hi, thanks for the suggestion, but I only want to rotate certain selected geometry, not the entire drawing. Is this possible?
Cheers
ian.mag
Hey
I think you may be referring to rotation using a reference.
Rotate command > select object(s)> type R(for reference) > select two points for your reference line >choose the direction of rotation???
in reply to: ian.mag
Perfect.
Thanks for your help!!
AutoCAD Inside the Factory
