AutoCAD Forum
SheetSet Manager attributes not printing
7 REPLIES 7
Message 1 of 8
bragiGCQM8
840 Views, 7 Replies
I have attached a template file in which I have defined attributes such as the sheet number.  These attributes do not print out.  Cannot figure it out.
Link to file...https://www.dropbox.com/s/nsydg61jhyn96yp/Aptoz%20A3%20Drawing%20Template.dwt?dl=0
7 REPLIES 7
Message 2 of 8
jayhar
in reply to: bragiGCQM8
Which version you using AutoCAD ?????
1. No error found in my System.
2. Update AutoCAD,  Select a Version available Click here
3. Run the Attsync command, update any existing blocks in the drawing
4. system variable ATTMODE has been set to 1
5. Text in Block Attributes not visible in the drawing Click here
6. How to create a new "DWG to PDF.pc3" driver in AutoCAD Click here
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | AutoCAD randomly crashes or freezes
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Message 3 of 8
Cadologist
Good morning... so I took a look at your template and unless I am seeing something incorrectly, the attributes you defined are not using Sheet Set Manager fields.
For Sheet Set Manager to work, you need to not only define an attribute (or text entity), but also add a 'field' to that attribute/mtext. Fielded attribute "link" the text to the Sheet Set Manager DST file. Let me explain - once you have added in Sheet Set Fields to all title block annotation, you then need to ensure the Sheet Set DST file also contains the same custom fields (i.e.: the Custom Property Name). You have to 100% be sure that whatever you named the custom property names in each field, correspond to the custom properties that you add to your DST file. If the names are not exactly the same, the information will not populate.
This may be why you are not seeing information printing as indented, because the Sheet Set Fields do not seem to be setup, and without that, the DST file cannot communicate to the sheet border/title block.
There are some EXCELLENT documents on the Autodesk Knowledge Network, check out the Mastering AutoCAD's Sheet Set Manager..... The link is below....
https://blogs.autodesk.com/autocad/tag/mastering-autocad-sheet-sets/
Chad Franklin
Message 4 of 8
bragiGCQM8
in reply to: Cadologist
Thank you.  I will try this out.
Message 5 of 8
bragiGCQM8
I am really having a hard time with this.  Can you take my file and setup a few of the attributes such that they update through the sheet set like the current sheet number and total sheet number?
Bragi
Message 6 of 8
Cadologist
I took a few minutes and added some Sheet Set Fields to one of the tabs within your Template file. The template I updated - use the link below to access.
https://filebin.net/7b4amk4vqiggdqb0
Take a look and let me know if you have any questions. You need to add these custom fields to your DST file as well, to create the 'link' between the Sheet Set Manager and the Sheet Borders/Title Blocks.
Fields Used:
  • CurrentSheetCustom (or CurrentSheetSetCustom, as required)
  • CurrentSheetNumber
  • CTAB - used to populate the layout tab name into the drawing number attribute, useful if you are using multi-layout tabs per drawing but want to insert the layout tab name into the Title Block vs. repeating the drawing's file name.
I have a class recording from Autodesk University 2018 where I discussed 6 Sheet Set Strategies for Success. Part of the class recording (and handout) overviews the use of Fields. Definitely take a look at that class if you are interested - link is below:
https://www.autodesk.com/autodesk-university/class/6-Sheet-Set-Manager-Strategies-Success-2018
Chad Franklin
Message 7 of 8
bragiGCQM8
Hi Chad.  There was no file attached to the post.
B
Message 8 of 8
Cadologist
Apologies, the upload didn't seem to work... I added a link to my reply above. Let me know if this doesn't work for you.
Chad Franklin
Forma Design Contest
