Instead of inputting an exact angle, or having to align to a horizontal/vertical line, could we please have the option to making a line within the selected geometry, horizontal/vertical. I'm certain this feature exists within other autodesk products.
Solved by ian.mag. Go to Solution.
Hi, thanks for the suggestion, but I only want to rotate certain selected geometry, not the entire drawing. Is this possible?
Cheers
Hey
I think you may be referring to rotation using a reference.
Rotate command > select object(s)> type R(for reference) > select two points for your reference line >choose the direction of rotation???
