AutoCAD Forum
Ribbon does not show the text description of the tabs
9 REPLIES 9
Message 1 of 10
juliewaddell1075
720 Views, 9 Replies
juliewaddell1075
The Ribbon Tab text does not show correctly.  Part of the text is cut off.  This is hard to see when I am just using my laptop screen.  Also, the length of the ribbon shows one of the tabs cut off.  Please refer to the attached snapshot for more clarity on this issue.  Please help me to resize the ribbon so I can view it clearly,
Sincerely,
JamJaws31
Sincerely,
JamJaws31
9 REPLIES 9
Message 2 of 10
Valentin-WSP
@juliewaddell1075
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
@juliewaddell1075
Emilio Valentin
Message 3 of 10
pendean
in reply to: juliewaddell1075
pendean
Community Legend
Community Legend
Windows11? No fix if any of the latest updates in your Autodesk Account Updates page do not help.
Or are you on an old monitor running in 1024x78 or lower resolution?
Or did you change the resolution/text size in Windows so you can see teeny tiny text in all of your other Windows programs?
Message 4 of 10
juliewaddell1075
in reply to: pendean
juliewaddell1075
I have Windows 10,  Version 10.0.19402 Build 19042, screen resolution is 1920 x 1080, text size is 100% (have tried changing this scale, but it did not effect the ribbon).
Sincerely,
JamJaws31
Sincerely,
JamJaws31
Message 5 of 10
pendean
pendean
Community Legend
Community Legend
I suspect one or more things in this article will solve your issue https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-c...
HTH
HTH
Message 6 of 10
juliewaddell1075
juliewaddell1075
I gave them a try. Nothing worked. Thanks for all your efforts.
Sincerely,
JamJaws31
Sincerely,
JamJaws31
Message 7 of 10
pendean
pendean
Community Legend
Community Legend
What is your exact AutoCAD version as listed in ABOUT command?
Message 8 of 10
juliewaddell1075
juliewaddell1075
R.163.0.0 AutoCAD 2021.1.2
Sincerely,
JamJaws31
Sincerely,
JamJaws31
Message 9 of 10
juliewaddell1075
Thank you!
Sincerely,
JamJaws31
Thank you!
Sincerely,
JamJaws31
Message 10 of 10
pendean
pendean
Community Legend
Community Legend
Start a support ticket through your subscription portal as explained here https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options#:~....
AutoCAD Inside the Factory
