AutoCAD Forum
Google earth file (KMZ / KML) to DXF/DWG
5 REPLIES 5
mansoormukkandath
30143 Views, 5 Replies
Can any one help me to import KMZ/KML file to Autocad. This KMZ/KML file having a route path only.
5 REPLIES 5
If you are running 2015 or higher and were to consider third party software, take a look at GeoLocationPlus.  It will import KML/KMZ files into your current drawing, export them back (Map Publish) and a lot more!
Command  - Mapimport
I just logged into the forum to say that OrxanSultanli's answer (MAPIMPORT command) is the CORRECT answer, instead of the reply marked as "Solution" in the thread.
pendean
in reply to: MachineMessiah
@MachineMessiah @OrxanSultanli MAPIMPORT is the wrong answer for the topic of this forum's software, aka Plain AutoCAD.
better luck next time.
Technology Administrators
