Can any one help me to import KMZ/KML file to Autocad. This KMZ/KML file having a route path only.
Solved by TerryDotson. Go to Solution.
If you are running 2015 or higher and were to consider third party software, take a look at GeoLocationPlus. It will import KML/KMZ files into your current drawing, export them back (Map Publish) and a lot more!
I just logged into the forum to say that OrxanSultanli's answer (MAPIMPORT command) is the CORRECT answer, instead of the reply marked as "Solution" in the thread.
