The Ribbon Tab text does not show correctly. Part of the text is cut off. This is hard to see when I am just using my laptop screen. Also, the length of the ribbon shows one of the tabs cut off. Please refer to the attached snapshot for more clarity on this issue. Please help me to resize the ribbon so I can view it clearly,
Solved by Valentin-WSP. Go to Solution.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
I have Windows 10, Version 10.0.19402 Build 19042, screen resolution is 1920 x 1080, text size is 100% (have tried changing this scale, but it did not effect the ribbon).
R.163.0.0 AutoCAD 2021.1.2
Thank you!
Thank you!
Start a support ticket through your subscription portal as explained here https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options#:~....
