So I want to change my bluish new theme color in AutoCAD 2022 back to the old gray color that was present in AutoCAD 2019. It seems that the AutoCAD for Mac community managed to figure it out (link below), but I can't seem to translate their results to Windows 10.
Any help is appreciated!
Thank you,
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Thanks but I know how to change the color scheme. I want to modify the dark color theme from being the blue color it currently is, to the gray color that was present in AutoCAD 2019 and earlier.
Not saying it was an option per-se. It was just the old theme color, it changed in 2020 by default. I've attached a snip of the old theme that was the standard dark theme color before 2020 (gray), as well as a snip of the new dark theme (blue). I'm trying to get the older color into AutoCAD 2022. If you refer to the link that was in my original post, you will see that this has been accomplished by the AutoCAD for Mac community, but I can not get it to work for Windows 10.
There are only "Two color themes are available for you to choose from, dark and light." -
How Do I Change the Application's Color Theme?
Its a matter of adapting, or change the Windows "Color Filter".
The users on the AutoCAD for Mac forums managed to solve this by modifying the base files for AutoCAD. I just can't seem to modify the base files to make it work on Windows. Here is the accepted solution from the referenced Mac forum post, and the user posted modified versions of these files in order to make AutoCAD revert to the old colors. It seems to work for multiple other users who downloaded the modified base files.
"There is no official way to change colours of Dark Theme back to 2019 "Dark grey".
The only way I've found is to edit two files inside AutoCAD application folder:
- Themes.xml - inside /Applications/Autodesk/AutoCAD 2020/AutoCAD 2020.app/Contents/Frameworks/AcTheme.framework/Versions/Current/Resources folder
and
- main.jsbundle - inside /Applications/Autodesk/AutoCAD 2020/AutoCAD 2020.app/Contents/PlugIns/AcAdvanceToolSet.bundle/Contents/Resources folder
The last one contains information about colours of Tool Sets palette."
I don't know how to do it, but I strongly defend your desire to revert. The 2019 and prior grays were much better, and they have the nerve to call the blue an improvement.
There's likely a UX expert and several studies which show the color selection as "more effective". However, despite being technically correct they don't always reflect the smaller user base in specific fields, especially technical ones. That's how we end up with a Fortnite-skinned engineering program.
@JBohman wrote:
Concurring vote from me, that this would be very nice to change.
Tell Autodesk all about it here anytime https://www.autodesk.com/company/contact-us/product-feedback
