AutoCAD Forum
Reverse spline to polyline conversion - Get spline back fewer segments
3 REPLIES 3
448 Views, 3 Replies
I've converted a spline to a polyline, and it asked me to apply a certain precision (1-99)
I selected 1, dividing my line up in a dozen segments. Now when working with this line I experience major delays and overall lag. When I import the line into Inventor to perform a sweep function along the line, the program gets stuck and doesn't respond.
Now my question is how do I convert back to the polyline that I used to have with fewer segments? I tried .PEDITSPLINEJOIN, without success.
version: AutoCAD 2021
J
3 REPLIES 3
pendean
Post a portion of your DWG file with this object, lets see what you are trying to work with. thx.
in reply to: pendean
Thanks for reaching out. I've just now managed to solve my problem. Took me the entire afternoon to figure it out. CVREBUILD did the trick for me. Removed all the unnecessary vertexes (it had around a 1000) Lag is gone and I can sweep along the path now. This board can be closed
cheryl.buck
Hi @Anonymous,
That's great news! Thanks for posting a follow up and sharing your solution with the Community. I have marked your post as the solution.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
Forma Design Contest
AutoCAD Beta
