Resizing Topo Survey
itsnathanblake
itsnathanblake
Hi guys,
Just been given a topo by an architect being in the wrong scale I'm trying to convert it to Meters so scaling the drawing 0.001 but everytime I do this it makes the drawing unusable. please open the attached and have a go at it for me and see if you can get it working.
itsnathanblake
Turned it into a block then scaled worked.
itsnathanblake
When moving it doesnt seem to move any of the texts on the points with it tho?
Valentin_CAD
Try this one.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Pointdump
Hi Nathan,
"...convert it to Meters so scaling the drawing 0.001..."
Your drawing is in Inch Units. If you use -DWGUNITS to convert to Feet, as Emilio did, then your coordinates match the grid ticks. You could then use -DWGUNITS again to convert, without scaling, the drawing to Meters, but at this point I have to ask what units will make your drawing "usable".
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
