2 different 3D Visual Style at same time
wr.marshall
Advisor Advisor
wr.marshall
is it possible to have 2 visual style at the same time. I.E. 1 object is set to realistic and 1 object set to conceptual or Wire Frame (not traced with lines...)
pendean
Community Legend
Community Legend
Only if they are in separate viewports in a layout (paperspace).
Valentin_CAD
Hello wr.marshall,
This is only possible if you have different viewports.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/AutoC...
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
