ordinate dimension leader lines
FORBESWILSON6174
FORBESWILSON6174
I have searched the forums, but cannot find any posts relating to editing the length of the leader lines when using Ordinate dimensions.
We have set up a project where the model drawings are set up in true X and Y values relative to the origin point, however when I use the ordinate dimension to give me the Y value and raise the text clear of the details, the length of the horizontal extensions are fixed from the dimension point and the text from the Jog.
I have tried dragging the points to shorten the lines, but they don't move.
Is there a way to shorten these lines, as they are causing a bit of a problem, especially on drawing with a small scale.
ВeekeeCZ
Changing an arrow size does help?
Kent1Cooper
As @ВeekeeCZ suggests, the "arrow size" [even though there's no arrow] controls the distance from your on-the-line grip to the bend [DIMASZ System Variable], and in the Text tab of the Dimension Style Modify dialog box, this:
controls the distance from that on-the-line grip to the end of the text part [DIMGAP System Variable].
Kent Cooper, AIA
