Issue data link_connection
vanzella.andreaa
vanzella.andreaa
Hi ,
I am facing some problems using "data manager properties".
Currently, I am following the instruction on a web seminar on Youtube (title: Beyond the Basics: Database Connectivity in AutoCAD 2017 WEBINAR | AutoCAD).
My issue is represented by the fact that when i try to select my ODCB, the window is fully blank so I can't pick anything, even if I update. I have tried to type directly the ODCB name, but it still doesn't work.
Reference of the window: Data link properties/Connection/Use data source name; Around 20.58 on the video
Valentin_CAD
Hello vanzella.andreaa,
Try using the information from this Autodesk Article (attached):
Other reference: To Create a Data Link to an ODBC Source
As final option, try Repairing your AutoCAD.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
vanzella.andreaa
Hi Valentin,
firstly, thanks for your support!
I have tried your reference but unfortunately with no good results. Following the pdf attached, the same problem mentioned before (screen1) occurs again, while attending to online guide, I don't have attached "AEC database" in the Field window (as you can see from screen3).
Btw, maybe this option are missing cause I have the student licence on Autocad 2022.
BR
Andrea
Valentin_CAD
 I don't see why there would be any limitation on a student license.  However, check with your IT Technical Support or if you have permission, perform a Repair.
You can also check the Educational Support HERE:
Emilio Valentin
