Is there a way to relocate the stretch grip (for a text entity in my case)? I don't want it to be lower left of the text but I want it located middle center.
Why not set Text Justification to "Middle Center" or use "Geometric Center" for the snap point?
In the case of Text specifically, there will always be a grip at the left end of the baseline, but with justifications other than Left [which you set in the process of drawing the Text, or afterwards in Properties], there will be another grip at the insertion point. Read in Help about the TEXT command -- it will tell you all about Justification.
My specific situation is that I have a group with text inside. I have the text to stay relative to the layout while the group can be rotated around it. The rotation of the text seems to be around the stretch grip. I want it to be around middle justification of the text itself.
I changed the Text's justification to Middle-Center as suggested in Messages 2 & 3 [and repositioned it a little], and added the yellow Point below at its new MC insertion point, and the red Point at its DXF-code-10 location [left end of baseline, common to all Text regardless of justification]. I am very disappointed to see that when the Group is rotated, while the Text maintains its zero rotation, it keeps its positional relationship to the red Point, not the yellow Point that I expected.
That seems a flaw, to me, having the actual insertion point not "obeyed" in this way [except with Left-justified Text]. I can't think of a way around that, but would not claim there isn't one. Maybe a dynamic Block could do it [I'm not well-versed in those].
